  • 112 Vote(s) - 3.27 Average
GM TIS2000
73
Hi everybody,
Is it possible to get a link for dongle free Tis2000 GM? At least V32.004 or newer. I would need it to calibrate the BPPS on a 20008 C6 Z06...
Thanks!
(05-24-2025, 03:21 PM)Kllauus Wrote: Hi everybody,
Thanks!
You'd use Tech2win or a tech2 for that, not sps programming from Tis2000.
Tech2win or tech2 BCM, BCM setup, BPP Sensor Calibration
Hi, I use a tech2 for a 2008 corvette c6 z06.
But there is no possibility to teach the bpps. If I choose 2009, there is a possibility but it doesn't work. There is a message "wrong car"...
Is ist possible that there is no need to teach the sensor, or doesn't it work with tech2?
tech2_card_gm_nao_v33.004_en, is what I use.
(05-25-2025, 12:17 AM)Kllauus Wrote: Hi, I use a tech2 for a 2008 corvette c6 z06.
I just checked with tech2win and BPP sensor calibration is present for 2008 for me.
Diagnostics, 2008,  passenger car, Y body, Vehicle Control Systems, auto/manual, uplevel/nav, onstar or not, Z06, Module setup, Body Control Module, BPP sensor calibration.
I am using 33.004 as well.
If it's there but failing then I would be looking at voltage at rest/not applied and can only guess switch is installed incorrectly or bracket is bent or some wiring issue. Voltage at rest needs to be a certain voltage or it fails.
Opel
05-25-2026, 11:51 AM
Vauxhall
05-14-2024, 02:10 PM
05-11-2022, 04:18 PM
