Alextn
Location OfflineJunior Member
0
Thanks Given: 0
Thanks Received: 1 (1 Posts)
22
THE ZAFIRA FROM HELL
2010 1.7 cdti
Replaced and checked the following from known good car:
Injectors, high pressure pump, fuel rail and sensor, turbo, EGR, EGR cooler, cat with sensors, dpf(someone drilled 2 holes) , checked timing, compression is 27 on all 4, replaced ecu, remap ecu with original file, checked all grounds to ecu with 21w bulb, MAF sensor, checked intake with smoke, checked vacuum hoses with smoke.
And still NO POWER and a LOT OF BLACK SMOKE.
I just got a handheld oscilloscope, what should I look at? Also if anyone could help me with some good known waveforms I would really appreciate it. Thank you guys.
This is my last hope to fix it. If not I'm going to scrap it.
fu7ur3
37
Thanks Given: 90
Thanks Received: 149 (53 Posts)
120
What is your AIR Filter/Cleaner looks like? 27 compression is kinda low, might be intake air leak.
Alextn
0
Thanks Given: 0
22
Air filter looks great, also tried without filter, no change. Compression is perfect
153
Thanks Given: 1173
Thanks Received: 876 (553 Posts)
905
56
04-02-2025, 10:12 PM
(This post was last modified: 04-02-2025, 11:02 PM by Bogdan Beb.)
No power and black smoke..
Can be egr opened, flaps closed, exhaust back pressure too high( will force to increase egr rate)
Check also camshaft sprocket blade key
Has the engine overrevved in the past due to oil in the intake?
don't forget to hit thanks and reputation buttons
31
Thanks Given: 34
Thanks Received: 45 (39 Posts)
348
81
Do smoke test. I think that you have air leak somewhere
180
Thanks Given: 210
Thanks Received: 282 (201 Posts)
482
87
04-04-2025, 01:51 AM
(This post was last modified: 04-04-2025, 01:52 AM by SirArevalo.)
Try to put a blank plate on egr exhaust gases pipe to cylinder head.
If helped hit "+Thanks" and "+Reputation" button .
Have a good day.
153
Thanks Given: 1173
905
56
04-04-2025, 03:40 AM
(This post was last modified: 04-04-2025, 03:43 AM by Bogdan Beb.)
Flaps are deleted but did you check if the vacuum is still present at the actuator?
Camshaft sensor reads on sprocket( pinion), so, the sproket key is ok? Can be broken and you ll not see any error but engine timing will be modified
Injector washer cooper have right dimensions?
