  • 119 Vote(s) - 3.47 Average
DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020
208
(02-09-2018, 08:28 PM)pesona Wrote: well, i am sorry fellas. i have to admit, that it was one year ago and i never look at it yet.
i hope someone could shed some light.
i still follow this thread and will make an update, if i can find something useful to add.
i very appreciate all the feedback.
Work fine in 12.2017 but i was say in #188 post here some file need !049
[/size]
BEST REGARDS!!Cheer2
Thanks given by: pesona , Rocinante , Pluto
209
(12-02-2017, 08:46 PM)xzt Wrote: Hi, I was tested your file pesona on version 12.2017, and after few test not work , but I was find that are missing some file, I was search old dvd flash data,to work normaly you need folder FDOK,file etns,etnh,etnt,etc from version old 2012,2011,2010,2009,for pkw,transp,smart tested and work fine in simulation with real vin car !
keep good work,regards!
aha, i will write this in the fist page. if not, then we will miss again something important information like this. thanks xzt mate.
Thanks given by: xzt , Marcos , Rocinante , Pluto
210
So i figured this out. For some reason as soon as I changed my DAS.inf version/date to match the flash data date it started working. The next issue was missing #FDOK folder which I copy/pasted. Everything worked after that.
Thanks given by: Rocinante , pesona , Pluto , tigex
211
(02-10-2018, 09:10 PM)megacrazy Wrote: So i figured this out. For some reason as soon as I changed my DAS.inf version/date to match the flash data date it started working. The next issue was missing #FDOK folder which I copy/pasted. Everything worked after that.
Can you show what exactly you changed?
212
I copied the entire 2016.5 release folder to SDFlash\Release. The "profi_cd.ini" file in that folder had "DAS-CD-NR=05/2016"
[DasDataVersion] in Das.inf was set to 2014 even though the "official" version I have is 05/2016. I changed that date to 05/2016
Basically as long as those 2 dates matched (in das.inf and profi_cd.ini) it wouldn't ask for the Star CD anymore and it would go to the next step of the flashing process, displaying flash data that was available. It also detected any ISOs I mounted, regardless where they were mounted from (same drive/usb etc.)
213
Perfect. That's what I thought you did. You confirmed it. Thanks.
214
Yes, I also changed it back to the old value to see if that was the issue and it was. As soon as I changed it, it went back to "insert star cd" when trying to program and not seeing an ISOs mounted.
Thanks given by: Rocinante , pesona , art_arev , Pluto
215
03.2018 is there solution?
216
(02-08-2018, 06:19 AM)Mackhack Wrote: Did you also replace the DAS.inf?
Pm prices me how much Ecom original thanks
