  • 119 Vote(s) - 3.47 Average
DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020
172
actually, i've finished the patch for retrofit offline half year ago (maybe more than that, 'cause it feels like a long time ago). i forget about it and forget the reason i have not upload it. Headbang
one thing i'm sure, i have not and i can not tested it. Lipssealed
btw, in real diagnostic life, is this retrofit offline das still be used?
with online connection that makes everything easier, is this old way still needed?
Thanks given by: Marcos , JarsaR , daxxer , Aldi , Landvogt72
173
(06-15-2017, 03:03 PM)pesona Wrote: actually, i've finished the patch for retrofit offline half year ago (maybe more than that, 'cause it feels like a long time ago). i forget about it and forget the reason i have not upload it. Headbang
Yes. For all the people who do not make money with this (haven't a garage) So they can not spent thousand of dollars for online account. I am such a person, too.
_______________________________________________________
Perhaps i can help via remote...ask me!
VeDoc-Access! -- Help for all possible Mercedes codings
Thanks given by: pesona , oleg71175 , Landvogt72
174
(05-31-2017, 09:46 PM)sparehellas Wrote: Ok guys,i got a stupid questions for ya all! Big Grin
I copy files and replace folders and stuff and i give it a test in Xentry Simulation,so it DOES show the Offline programming as an option BUT no matter which VIN i put,either it is a Sprinter or a PKW,it pops a message,for example on Sprinter it says "ETK 906 vin series model not found." and then it prompts to incert a CD.
To explain,i never tested it before on real car,only in simulation to see how it works before i explode any ECU. Big Grin
So the stupid questions i got for you all is:Offline programming works only in real cars?Or it should also work in simulation and i do sth wrong???
I repeat i never tried it so far on real car,only Simulation...
You're getting this error because your SDFlash directory is missing things. Download the 2012-11 SDFlash from here:
http://mhhauto.com/Thread-SDFLASH-Collec...ht=sdflash
If you have all of the correct files you should be able to get to the last step of doing an update in the simulator. I just did a Telematics update on a W221, using DAS/XEntry 2014.12 with the 2014 ver 1.01 patch from this thread and the PKW directory from the SDFlash that I already linked to.
175
Error comes from using cracked DAS Standalone. If you go the legit route via Xentry that error will not pop up. Of course all files need to be at the right places too. Pesona did an awesome job here and it works every time I use it.
Thanks given by: pesona , JarsaR , daxxer
176
I don´t have a garage as well and I wanted to ad the rain sensor to my w208 without going to the dealer to get it coded. I think to retrofit it should not be a big deal. actually it is build already in my car need just to activate the function.
(06-15-2017, 10:48 PM)Mackhack Wrote: Error comes from using cracked DAS Standalone. If you go the legit route via Xentry that error will not pop up. Of course all files need to be at the right places too. Pesona did an awesome job here and it works every time I use it.
Tryed the way through xentry as well. was not working, too.
My Youtube channel
https://www.youtube.com/c/JWAutomotive
Check it out and subscribe ;-)
177
Will you put the retrofit patch into this thread?
My Youtube channel
please don't wait it. There must be a reason, i didn't upload it at that time. i plan to check it again on next week holiday. if the patch is good, i will gladly upload it here mate.
179
thanks a lot
My Youtube channel
Hi Pesona
thanks for the Sharing all this stuff but i ahve nothing seen about trucks is this correct or possible ??
RG TKS12
Hi Pesona
RG TKS12
