  • 119 Vote(s) - 3.47 Average
DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020
73
hi,
your xdos sdflash doesn't have the etn information needed by das to looking for the flash file.
download the sdflash collections in my bottom first post. try the 2014 version first.
mount the iso file to 'virtual drive'.
i have not study yet how to look for precise flash file needed when offline programming.
Thanks given by: alexjx , pcsmed , efka
74
(12-08-2016, 03:26 AM)pcsmed Wrote: hi
have an problem with DAS xentry 2016 and C5
trying to software update my command in my w221 420L cdi from 2007 EU car
i have the offline programming working.
here i press F3
now i am getting this message
the vin number is correct
i press F2
and i get this
i press OK
do i have the wrong Akttab file ?
i used the one from the first post
i press F3
i don't have that CD do i need it ?
if so do any one have the cd number for my car or
do any one have a solution
thanks to pesona for this offline solution
it almost works on a w221BlushWink
i do have the problem like these previously.
then i copy over the files from my 2014/3 das and it works again.
since pesona has the link on the front page, download it and have a try again. Wink
Thanks given by: pcsmed , pesona
75
will try that when i get home from work today
and a 1000 thanks for the fast replay
Thanks given by: pesona , alexjx
76
It will def. work that way.
nope dit not work
now i got this
i did copy all from that SDFLASH 2014-09.iso
is it only some off it i have to copy ?
got it to work
used SDFLASH 2013-11.iso and copy pkw library to HD (overwrite)
then i copy the original pkw library back and overwrite
other wise you get the above error
now i need the Telematics DVD 03/2010 for w221 mb nr. 2218278759_0001
i thought i hade one but the command will not accept it ( looked like the real one )
do any one have an link or copy to this one
i found an link in here but it was dead
Thanks given by: pesona , oleg71175
79
for the above error, you can easily edit the profi_cd.ini and change the date or just choose 'NO' for the above question.
imo, it is not wise to overwrite the original folder. better rename and copy the other version.
Thanks given by: Rocinante , pcsmed , marcobh5 , JarsaR , mercomoh
80
(12-08-2016, 09:10 PM)pcsmed Wrote: nope dit not work
now i got this
No just mount the ISO. Done. DAS and XENTRY will look there automatically for the correct cff files.
Thanks given by: pesona , Rocinante , weryo , pcsmed , JarsaR
81
Thanks everyone
it is Company Christmas party day so i wont be doing anything to the car for a couple of days
did edit the cd id on the telematics dvd a had
DAS accepted the dvd but the command made a error saying it could not find the right file for updating so i thing i have the wrong dvd
so if anyone have the Telematics DVD 03/2010 for w221 mb nr. 2218278759_0001 to upload it would be nice
here is the Telematics DVD 03/2010 for w221 mb nr. 2218278759_0001 i got
if anyone can see if it is the right one
have changed cd_info file in line 2 to 2218270065
.txt
Telematics DVD 03-2010 for w221 mb nr 2218278759_0001.txt
110
84 bytes
