  • 119 Vote(s) - 3.47 Average
DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020
127
(02-17-2017, 09:37 AM)mobileclimate Wrote: To fix missing ETN 906 and VeDoc for sprinter vans (2007-2009 Dodge sprinter)- offline programming must have 11/2013 FLASH DVD make a copy of sdflash release folder overwrite files with 11/2013 DVD and then copy the original back ...works perfect on 12/2016 xdos ...you can just make copy of profi_cd.ini of 12/2016 xdos and use 11/2013 and 07/2014 over write files in folder..works perfect in simulation and real with NO ERRORS at all
I attched a pic of missing ETN for 906 van
and missing Vedoc
Sent from my iPhone using Tapatalk Pro
Have a sprinter myself and as you said theres no code for the 906.Are you able to upload the 11/2013 files that id need, dont have a copy of it. Thanks
SD FLASH
Sprinter III 2007 to 2013 can be offline flashed...2014 to current you need online account
906etn.rar
106
113.52 KB
Thanks given by: pesona , Aldi , Tboz.jnr , techm3 , dusichek2012 , Backmann
129
(02-24-2017, 10:49 PM)mobileclimate Wrote: SD FLASH
Thanks downloading atm, will see. It works offline, but then veDoc data for 906 not available. Have replaced SDflash with 2012.11 files i have and amended the profil_cd.ini file to 2016 settings etc, but still not working. Ideas?
Thanks given by: kaya1923
130
The missing etn 906 and vedoc files are on the 11/2013 DVD you cannot offline flash any sprinter that is 2014 and newer
Code:
https://mega.nz/#!PspkRbwb!1sNNPQVa6QBgBcZHoYQgeHdwzt_rqSQzj_40OaTZQss
Thanks given by: pesona , kaya1923
131
Code:
Thanks, you also got a link for SD Files 2012/12? Sprinter is 2007 so no problem there. Cheers
Code:
you dont need 12/2012 dvd ..11/2013 has everything ..you still need to offline SCN code ..which i know how to do using special function no password and adjusting the variant coding ..If you want to pay me ill show you how to code without needing online account ..ESP controller update you will need to change coding or will you be driving with error codes on dash Smile
133
and missing Vedoc
hi mobileclimate,
thank you so much for your valuable feedback in offline Transporter programming.
with feedbacks from bulayooo (post no 28) and you, regarding offline Transporter programming, i update my first post in this thread with new transporter inbetrieb.
it covers ALL transporter type in DAS upto 03-2017 and with it, you don't need to mix and clutter your sdflash in your harddisk drive again.
you can mount your 2013 sdflash and/or 2012 and/or 2014 collections in virtual drive and 2016/2017 in harddisk drive and let DAS search the needed files in those ALL SDFlash.
For xdos 03-2017, all offline programming are still valid. Only need to patch one file in das\bin and one file in sdflash folder (optional).
I will update my first post asap.
Thanks given by: laco210 , Jurgen02 , Marcos , art_arev , zalimhan74
134
There should be a warning about updates on the Sprinter ESP module...you need to record the coding settings before updating that module ..if you dont the cdi and ki wont recognize the controller intill you either scn code or change variant
Thanks given by: pesona , tigex , zalimhan74
135
(03-03-2017, 12:53 AM)mobileclimate Wrote: There should be a warning about updates on the Sprinter ESP module...you need to record the coding settings before updating that module ..if you dont the cdi and ki wont recognize the controller intill you either scn code or change variant
If one updates a control module it's his sole responsibility to know what he's doing. Even on a legit SD doing offline back in the days or SCN today the system won't warn you.
Let's not put the burden on peson's awesome work, please. Without him we wouldn't update at all.
Thanks given by: pesona , JarsaR
