  • 119 Vote(s) - 3.47 Average
DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020
154
Ok i will do that now
Sent from my LGMS330 using Tapatalk
(03-03-2017, 12:53 AM)mobileclimate Wrote: There should be a warning about updates on the Sprinter ESP module...you need to record the coding settings before updating that module ..if you dont the cdi and ki wont recognize the controller intill you either scn code or change variant
Update: its the KI settings that mismatch the esp controller ..make sure they have same settings
Thanks given by: pesona , art_arev
156
(07-27-2016, 04:16 PM)pesona Wrote: Today i go to my friend to test this offline programming myself.
W204 and W211. Tested and it works.
Now, i need your help mates.
1. I was ask by a member here that he stumbled with release code and test digit 2, like this:
where do you get this numbers?
i think i know how to bypass it if i connect with the car and stumble with that.
but i need to know, if you don't bypass these numbers, where and how do you get this number from?
2. am i safe if don't connect battery charger?
offline programming commercial vehicles, wil begin after switch engine and start OFF. That's why i have peace in mind and don't need battery charger. for pkw, i read that the fan will on hardly etc etc..
i will continue with F3. but before that i need the information please.
Hallo pesona
do you hawe bypass for VGS3 release code and test digit 2 ????
not yet mate. according to a great member here(Kaluluka), he informs me that i can do it using DAS 2012 version and without the seed code. so i bypass the code in latest DAS.
but i don't get the car to debug it and i already forgot.
with your post, i remind there is also another similar powerful DAS sonderfunktion for PKW that can be done offline but need special password.
Reset(virginize) any ecu using Dealer hash in DAS. VVDI BGA cant reset some of ECU's but DAS can do it all offline.
thanks & best regards
Thanks given by: laco210 , Marcos , spajdermen , JarsaR , Aldi
158
Hello all. Where can find offline patch for 03.2017 pkw. Patch in topic - dont work.
hi mate,
try this and please give feedback of the result
http://mhhauto.com/Thread-DAS-PKW-SMART-...#pid905945
Thanks given by: Marcos , spajdermen , Rocinante , art_arev , avandgarde
160
(03-13-2017, 02:19 PM)pesona Wrote: hi mate,
Hello. Dont work. after run offsynk (with admin rules \ without) - i get error.
Code:
http://take.ms/BPnRp
http://take.ms/MMP4R
(07-26-2016, 05:10 PM)pesona Wrote: Hi,
here is offline programming for
vehicles: PKW + SMART
Software: Xentry XP, XDOS(32/64)
Release: 2015 until 12-2016.
Full flashen folder + how to
How to: (1.01)
1. Rename original flashen folder in: das\trees\pkw to e.g: flashenORI
2. Extract and copy the offline flashen
So in the das\trees\pkw you have two folders:
Flashen ; for offline programming
FlashenORI ; original folder. Maybe you want to use for online programming
Make a simple batch file to have a menu to choose “OFFLINE” AND “ORIGINAL” to switch between these folders.
It is better including changing the name of Flashen folders in SMART too.
here it is ver 1.0: (Not Full Flashen folder)
ver 1.01 (full flashen folder) + add 204.041 in [Offline ablauf]
notes:
- for some xdos release, there is no akttab.csv in the PKW sdflash folder
here it is:
SMART
Full Flashen folder
Need Offline Programming PKW installed
how to:
1.
Rename SMART Flashen folder in:
DAS\Trees\Smart\Flashen to
FlashenORI ; original folder. in case you need to use for online programming
2. download the OFFLINE Flashen and extract this folder to
DAS\Trees\SMART
so you have 2 folders.
1. flashen (with offline capability)
2. flashenORI which is the original
here it is version 1.0:
Software: Xentry XP
Release: 2014 until ... (I will check later or get feedback from member)
Full Flashen folder + how to
How to: (1.01)
MENU
This is example of menu file that you can use to choose Offline or Original.
Compatible with: WINXP and latest OS
For: Xentry XP, XDOS 32bit, XDOS 64bit
Version: 1.1 (Include PKW, SMART, TRANSPORTER/VAN)
UPDATE:
Notes:
- copy to desktop. it will know what OS, and 32/64 bit automatically
if the menu above is failed on your OS, here is the source file that you can adjust or delete the determination of OS.
ONLINE: Wink
cmiiw,
If your Xentry is not the 2-3 latest release, but somehow you want to SCN Online, to avoid vpo-5/vpo-12 error, BACKUP the original file, extract and copy this file to your:
Sdflash\Release\PKW; Sdflash\Release\SMART; Sdflash\Release\TRANSP;
From 07-2016
TRANSPORTER/VAN
Full Flashen folder
how to:
1.
Rename TRANSP Flashen folder in:
DAS\Trees\Transp\Flashen to
DAS\Trees\Transp
It is better including changing the name of Flashen folders in ALL (PKW, SMART, TRANSP).
here it is version 1.0: (q.e.d. proven here)
here is offline programming for:
vehicles: Transporter
Software: Xentry XP
Release: 2014
How to: (1.0)
1. Rename original flashen folder in: das\trees\transp to e.g: flashenORI
TRANSPORTER/VAN AKTTAB.CSV
here is replacement for missing "akttab.csv" in Transporter e.g 12-2015, 09-2016 version etc
Transporter INBETRIEB.INI V2 Released in 03-2017 for All DAS Version :
what's new:
1. it covers ALL Transporter vehicles in DAS (from 4 transp type to 16 transp type)
2. it will recognize sdflash in virtual drive
how-to:
- extract & replace the inbetrieb.ini of the "offline Flashen" in:
DAS\trees\Transp\Flashen\ini\
here it is:
Disclaimer:
for official and educational use only. If you use them for any illegal purposes (such as programming stolen car/smart/van), this is your own responsibility. i'm definitely against it.
EDIT:
I remove the statement that these patches can be used with xdos passthru. I just got information from weryo, that xdos passthru can't be used for programming..
here is his statement:
http://mhhauto.com/Thread-Xdos-05-2016-e...#pid804207
(10-25-2016, 10:02 AM)weryo Wrote: Xentry passthru and passthru interface cannot see if ignition is on or off,..because of its structure!
Its very different situation than normal xentry!
Thats why developers use the trick from simulation box that offer you to switch on or off ignition using software,..not phisically!
But in programing sessions this box become inactive,and you are not able to
continue!
Also in xentry passthru instructions they clearly describe that its only for basic diagnostics,..not for coding,programing ,..etc!
I recently sow a person that tried to program engine ecu ME97 with passthru,..and the ecu died!
SDFLASH-Collections
DAS Offline Programming 2017
Hi dear members i have install das-xentry 09.2016and have fix this fix for Offline Programming but offline programming dosnt work see picter please help
Everything works. Read instructions carefully, copy files in the correct folders & it will work nicely
Art Tup
Thanks given by: Mackhack , pesona , Rocinante , JarsaR
