3,178
Thanks Given: 7612
1,696
53
pm audiomeca or jokeriphone. they are some of the experts in smart vehicles.
63
Thanks Given: 93
Thanks Received: 200 (61 Posts)
382
54
I need to coding a new sam virgin in Smart 451 my2009. It's possible or not?
Now i have select OFFLINE Coding but see "INSERT VecDoc DVD"
73
Thanks Given: 138
Thanks Received: 144 (35 Posts)
362
138
122
02-21-2017, 11:31 PM
(This post was last modified: 02-21-2017, 11:34 PM by Dronx81.)
I tryed this guide with xentry 09/2016 and pwk+smart, i have copied into flashen folder but when i try to program offline gearbox ecu 451. I receive who not find the flash file into the drive.
I have used all sdflash(2008,2009,2010,2011,2012,2013,2014,)iso mounted with alcohol. And one usb drive with cff file of ecu into directory. Principal
What can i resolve this problem?.
There is a directory where i put this file or folder for do understand to xentry where to get the files for offline programming?
3,178
Thanks Given: 7612
1,696
53
hi Dronx81 mate,
if you already have the cff file asking by das, you can mount the sdflash iso or
copy that sdflash into
c:\program files (xxx)\mercedes-benz\sdflash\release\smart
don't forget to backup it first.
73
Thanks Given: 138
362
138
124
02-22-2017, 10:22 AM
(This post was last modified: 02-22-2017, 10:24 AM by Dronx81.)
Yes i have the cff file but when insert flash file into directory correct...or mount the iso with this cff or usb pen drive with cff file on pc xentry give me " fhe file is not found...possible cause:
File is not compatible.
The cd or usb are damaged. Etc...
I cant activate offline programming.
12
Thanks Given: 97
Thanks Received: 62 (35 Posts)
217
25
Great work! Just an information: with this patch we can upgrade with the latest flash files included in DAS or there is always the problem of no VeDoc files because they're only online now?
3,178
Thanks Given: 7612
1,696
53
mobileclimate has given us a great hint. i hope y'all that works with (cars, smart or transporter) would share your experiences with others.
