3,178
Thanks Given: 7612
1,696
53
hi sisdisru,
look at your pkw sdflash folder, in this case is
c:\program files (x86)\mercedes-benz\sdflash\release\pkw
if there is already akttab.csv, then you don't need it.
if not, then copy only to pkw folder
this akttab.csv is only for pkw.
110
Thanks Given: 293
Thanks Received: 427 (69 Posts)
232
19
12
07-28-2016, 05:12 PM
(This post was last modified: 07-28-2016, 05:13 PM by schou.)
I programming a w211 MY2005's ME97 engine control module with your solution, it didn't ask for release code neither.
I use C4 with XDOS(x86) 07-2016
156
Thanks Given: 461
Thanks Received: 613 (355 Posts)
818
74
(07-28-2016, 05:12 PM)schou Wrote: I programming a w211 MY2005's ME97 engine control module with your solution, it didn't ask for release code neither.
me control unit?
did it ask for a scn coding after everything?
Thanks Given: 31
Thanks Received: 3 (3 Posts)
13
14
07-29-2016, 12:51 AM
(This post was last modified: 07-29-2016, 12:55 AM by heiko_audi.)
Today I tried your solution on W219 CLS. I can choose now online or offline programming. So everything should be fine. But when I try to upgrade MEG on smart 450, then I get error message:
"Error: Service ´MainSmartFlashRelease´ not found"
What could be the problem? I´m working on 12-2015 native install win XP Compaq Evo N410c with C3 mux.
Thanks in advance.
Greetings.
3,178
Thanks Given: 7612
1,696
53
hi heiko_audi mate,
thanks for your feedback. I've updated my first post.
if you do offline programming in real, please give feedback.
Thanks Given: 31
13
I´m on holiday now. I can test your solution on smart in 2 weeks. I will post result here, thanks again.
Greetings...
3,178
Thanks Given: 7612
1,696
53
17
08-07-2016, 06:51 AM
(This post was last modified: 08-07-2016, 07:24 AM by pesona.)
btw,
i have found the files that make online/offline programming EGS2 and EGS3 need seed key (Release Code). I will try to look at it, and solve it if i can.
Please give me information, if other ecu(s) needs seed key in offline programming.
as you know, probably, Daimler spy this forum, is it wise if i do this?
