3,178
Thanks Given: 7612
1,696
53
hi too,
noted mate. make sure your hardware are health using self diagnosis in star utilities.
anttist
Location Offline Junior Member
Thanks Given: 12
Thanks Received: 4 (3 Posts)
14
Here's my self diagnostics log. Does it look allright? I have tried with USB<->RS232 adapter and Expresscard RS232 port. They both seem to work the same, but in fact they both use Prolific USB<->RS232 chipset so although the form factor is different they work the same.
If this is likely to be a communications issue I could try to loan a docking station with serial port.
Thank's for your great work!
PartD_20161024_220248.txt
anttist
Thanks Given: 12
14
39
10-27-2016, 11:08 PM
(This post was last modified: 10-28-2016, 01:35 AM by anttist .)
I tried FTDI USB-RS232 adapter and re-installed everything. No difference. Has anybody got the smart offline programming working with this solution?
I noticed that even when trying to program MEG Control Unit on upper right corner always says SAM_450. Maybe this is normal, I don't know.
EDIT: I tried programming the SAM which also had new version available and that was successful! So it seems to be related to the MEG somehow.
3,178
Thanks Given: 7612
1,696
53
hi mate, thanks for the feedback.
it would be perfect if you kindly make the screenshots of your smart programming and upload it here.
0
Thanks Given: 2
Thanks Received: 3 (1 Posts)
0
I have version 9/15 and installed the transporter/van patch. I am unable to do offline programming because it requires a password. Did I do something wrong or does this patch have a password. Thanks
89
Thanks Given: 149
Thanks Received: 200 (15 Posts)
46
Great job, thank you so much.
meson, lepton, muon...
103
Thanks Given: 474
Thanks Received: 840 (531 Posts)
1,358
41
This is what I get when I try your menu program on Win XP with Xentry 12/2015.
Any idea what's wrong?
Thumbnail(s)
