3,178
Thanks Given: 7612
1,696
53
i will look the source of the batch file and upload it here. you can play with it.
i wish i could make good installment and nice menu in the next coming xmas holiday.
Venya
Location OfflineJunior Member
11
Thanks Given: 205
Thanks Received: 45 (20 Posts)
59
Hi Pesona,
thanks for your Work. With PKW more or less OK.
If I try to flash a Transporter eg. Sprinter 906 or Viano 639 occurs the error "ETN for model series XXX could not be found".
My XD Version is 09/2015 Windows XP German.
3,178
Thanks Given: 7612
1,696
53
your sdflash folder (09-2015 in this case) doesn't have it. try to use sdflash from older xentry version (e.g 12-2014 sdflash), make iso image and mount it in virtual drive.
hope this help
103
Thanks Given: 474
Thanks Received: 840 (531 Posts)
1,358
41
His solutions work. I flashed at least 15 different control modules since installed.
16
Thanks Given: 372
Thanks Received: 99 (39 Posts)
192
30
52
11-13-2016, 12:34 AM
(This post was last modified: 11-13-2016, 12:34 AM by liakontas.)
hi pesona.
i also tested the offline programming and it worked on every car i used it..
the problem is that i dont know to make a batch file to use the online and offline programming...this is what i get when i use your menu offline or online..is it the problem on the file or on me?
