(12-22-2025, 11:40 PM)nicu_cuc Wrote: to solve this error
add ISPIDATA C:\ProgramData in System variables
and all will work ok
For lazy ones, Just run ISPIDATA System Variables as administrator
enjoy
Thanks!!!
enjoy
(12-21-2025, 07:16 PM)tmks2 Wrote: Bmw ISTA-PLUS 4.57.21 Programming data 4.57.21 full тояяёит
German and English language
Free no pass!!!
Works with D-CAN ENET ICOM
Additional changes!!!
- Disable Fake FSC Reject
- ENET Programming Enabled
- Re-астїvатёd ICOM A1/A2
- Works with DCAN
- fїж rescan old DS2 vehicles
- вурдs ignition detection with DCAN/Ediabas (click cancel and it continues)
- Motorbike ignition detection disable with ENET
- Disabled FASTA (Data Not Send) And many more!!!
- Ista has no visual www... ads… clean system just like the original
This is the latest version and is not fully tested
update...
Post 20 common problem fix "Failed to start ISTA. Please make sure your ISTA configuration is valid"
Ista has active programming! and without full psdzdata it will not work!!!
(05-10-2026, 05:42 PM)Binde Wrote: Hello perhaps someone can help me with my problem. I had used this pc with order ista version and tried installing this. Done by instruction but I can't connect to vehicle.
Ista finds my icom device when get warning that it connected directly by lan.
When it tried to finds vehicle I get error that unexpected fault... Adding photo with information.
(05-12-2026, 11:30 AM)Binde Wrote:(05-10-2026, 05:42 PM)Binde Wrote: Hello perhaps someone can help me with my problem. I had used this pc with order ista version and tried installing this. Done by instruction but I can't connect to vehicle.
Someone perhaps had this issue?
(12-23-2025, 02:29 AM)tmks2 Wrote: common problem fix "Failed to start ISTA. Please make sure your ISTA configuration is valid"
please add ISPIDATA C:\ProgramData in System
or Run with the administrator ISPIDATA System Variable
Free no pass!!!
- Works with DCAN
update...
