[email protected]
ISTA+ 4.57.21 standalone
common problem fix "Failed to start ISTA. Please make sure your ISTA configuration is valid"
please add ISPIDATA C:\ProgramData in System
or Run with the administrator ISPIDATA System Variables
Thanks given by: rabihfiras , Erikas , stolojan , turbozob , kvxx , ponukka , zebek6 , scorpion4x4
23
12-23-2025, 02:53 PM
IMPORTENT !!!
Ista has active programming! and without full psdzdata it will not work!
Thanks given by: Felixir , Verado400M
27
12-24-2025, 12:27 AM
Hi
Thank you so much for sharing, everything works perfectly following your instructions... after the third installation
I figured it out: you shouldn't extract the file to C: with the Windows utility, but you should use WinRAR.
And if a kind soul could give me a link for the French SQLite version, that would be great.
Thank you very much.
Thanks given by: Verado400M
![[Image: 2025-12-22-235519.png]](https://i.ibb.co/sdGJNzfx/2025-12-22-235519.png)
![[Image: 2025-12-22-235434.png]](https://i.ibb.co/dJ19nrMx/2025-12-22-235434.png)
![[Image: 2025-12-22-224607.png]](https://i.ibb.co/X0vr7Gf/2025-12-22-224607.png)
![[Image: 2025-12-22-222237.png]](https://i.ibb.co/gb2NjQqK/2025-12-22-222237.png)
![[Image: 2025-12-22-223441.png]](https://i.ibb.co/x8MQWZkY/2025-12-22-223441.png)
![[Image: 2025-12-22-223656.png]](https://i.ibb.co/SXsbjnjg/2025-12-22-223656.png)
![[Image: 2025-12-22-224102.png]](https://i.ibb.co/YF6YQcdY/2025-12-22-224102.png)
![[Image: 2025-12-22-235844.png]](https://i.ibb.co/W44TK0ys/2025-12-22-235844.png)
![[Image: 2025-12-22-215948.png]](https://i.ibb.co/GfDZqSYS/2025-12-22-215948.png)
