Sorry, I was being stupid — I had downloaded the wrong version and not your version of the program. Now everything works perfectly. Thank you very much again. I just have one more question: in my old version I was still able to select the vehicle without entering the chassis number. Is that no longer possible in the new version?
[email protected]
ISTA+ 4.57.21 standalone
29
12-24-2025, 12:44 PM
(12-21-2025, 07:16 PM)tmks2 Wrote: Bmw ISTA-PLUS 4.57.21 Programming data 4.57.21 full тояяёит
German and English language
Free no pass!!!
@vagrom thank you for the ратснёя
Works with D-CAN ENET ICOM
Additional changes!!!
- Disable Fake FSC Reject
- ENET Programming Enabled
- Re-астїvатёd ICOM A1/A2
- Works with DCAN
- fїж rescan old DS2 vehicles
- вурдs ignition detection with DCAN/Ediabas (click cancel and it continues)
- Motorbike ignition detection disable with ENET
- Disabled FASTA (Data Not Send) And many more!!!
- Ista has no visual www... ads… clean system just like the original
This is the latest version and is not fully tested, if something goes wrong, delete the folders!
update...
Post 20 common problem fix "Failed to start ISTA. Please make sure your ISTA configuration is valid"
Ista has active programming! and without full psdzdata it will not work!!!
Is there a repair manuals ?
yes this is full version
write VIN
(12-24-2025, 02:45 AM)haaaq Wrote: Sorry, I was being stupid — I had downloaded the wrong version and not your version of the program. Now everything works perfectly. Thank you very much again. I just have one more question: in my old version I was still able to select the vehicle without entering the chassis number. Is that no longer possible in the new version?
write VIN
last torrent link was dead, this one goes nicely quicker
32
12-26-2025, 01:22 AM
I downloaded and installed it on windows 11, it's totally as expected, thank you very much!
It's just that connecting with enet wifi mode takes a little too long... I haven't had time to test with icom but I'll keep looking to see what I can do to increase the speed with enet
33
12-26-2025, 05:19 PM
(12-26-2025, 01:22 AM)Msasha Wrote: I downloaded and installed it on windows 11, it's totally as expected, thank you very much!Hi
Did you had installed the Standard Tools ?
Try uninstall the Standard Tools and delete all files and folder for standard tools is checking first step , If installed
Best Regards
If my post can help you , Thanks + Reputation will be appreciated
34
12-27-2025, 04:14 PM
You don't need to uninstall standard tools.
Just rename the folder off_ediabas in C:\ediabas
36
12-30-2025, 12:02 AM
(12-28-2025, 11:11 PM)000dddav Wrote:(12-27-2025, 04:14 PM)tmks2 Wrote: You don't need to uninstall standard tools.
Where is this folder located?
I don't have instaled yet standard tools, I was wrong, it connects normally, the first time I tested with enet wifi on a g05 with many options, but today I worked with it with icom wifi on other cars and everything is ok so on the e,f,g series
Thanks given by: tmks2
