  • 3 Vote(s) - 3.67 Average
ISTA+ 4.57.21 standalone
73
[quote="over73" pid="3246418" dateline="1769242176"]
Hello all,
  1. I have freshly installed Windows 11
  2. I unpacked ISTA to C:/
  3. Created a shortcut on the desktop
  4. Copied the BMW directory to C:/ProgramData/
  5. Executed the registry file
  6. Checked .NET Framework – it is the latest version
  7. Installed C++
  8. I start ISTAGUI.exe
An error message appears.
What did I do wrong?
Post 20  common problem fix    "Failed to start ISTA. Please make sure your ISTA configuration is valid"
Thanks given by: maxxx333
74
(01-22-2026, 05:00 AM)NoxX Wrote:
(01-20-2026, 02:37 PM)maxxx333 Wrote:
(01-19-2026, 01:31 AM)NoxX Wrote:
(01-17-2026, 04:19 PM)maxxx333 Wrote:
(01-12-2026, 03:04 AM)osoriko Wrote: Don't download. Not working.
How long did it take you to read everything completely?
[Image: 20260109-173833.jpg]
very fast
standart time
And for me it takes 27 minutes, that's not normal.  I used an ENET cable to read the data and I installed everything correctly.
27 minutes?
Are you serious?
+/-3 minutes my diagnostic test (+/-)
BMW X7
(01-17-2026, 04:19 PM)maxxx333 Wrote: How long did it take you to read everything completely?
very fast
standart time
27 minutes?
Are you serious?
BMW X7
I'm really serious   Previously, BMW ISTA-D 4.52.40 was installed, and that was also very slow, like 4.57.21    What was fast was version 4.22.40 And I don't want to reinstall Windows because of E-Sys, which works. Is it due to ediabas? Is it perhaps outdated?
(01-20-2026, 02:37 PM)maxxx333 Wrote: very fast
standart time
27 minutes?
Are you serious?
BMW X7
I install to clean Windows 10x64
Today tested with E series
Work fine and very fast
DCAN cable
Thanks given by: tmks2
78
Hi, I get and error about PAD not detected it means doesn't detect the ignition ON, any solution, also cant install BMW tools 2024 along side this ista?
Is working I install all MS C++, netframe 4.81, and install PZD Data in the right directory, hope It helps someone
"I’m having a problem reading my vehicle – an error keeps appearing. Can someone please help me?"
(12-21-2025, 07:16 PM)tmks2 Wrote: Bmw ISTA-PLUS 4.57.21 Programming data 4.57.21 full  тояяёит
German and English language
Free no pass!!!
Works with D-CAN ENET ICOM
  Additional changes!!!
- Disable Fake FSC Reject
- ENET Programming Enabled
- Re-астїvатёd ICOM A1/A2
- Works with DCAN
- fїж rescan old DS2 vehicles
- вурдs ignition detection with DCAN/Ediabas (click cancel and it continues)
- Motorbike ignition detection disable with ENET
- Disabled FASTA (Data Not Send) And many more!!!
-  Ista has no visual www... ads…  clean system just like the original
  This is the latest version and is not fully tested
 update...
Ista has active programming! and without full psdzdata it will not work!!!
Today I connect to a G01 2022 the system closes when I try to print to a file, I did show the options for printing, then I try to print the Full report and there is a blanck option on printers and shuts the ista down, any ideas? and thank you for your contribution
I am getting this error, can someone tell me what issue is this?
Yesterday, 10:16 PM
06-10-2026, 12:05 AM
