  • 76 Vote(s) - 2.79 Average
zafira pump psg16 replacement and programming
82
after reflash psg16 with tis and tech 2 ecu is not resetted to pair with immo. if a try to program immo it say : both ecu cim and engine are programed. how to reset engine ecu.
i read again pump ecu with car prog and attasched the file
bunpsg.rar
9.74 KB
(04-23-2024, 07:26 PM)danieltnokia2000 Wrote: after reflash psg16 with tis and tech 2 ecu is not resetted to pair with immo. if a try to program immo it say : both ecu cim and engine are programed. how to reset engine ecu.
Pin 1044        VIN: W0L0ZCF6931108765
Thanks given by: danieltnokia2000
84
(08-04-2012, 08:13 PM)sokisoki3 Wrote: hi
I know immo module and key with new pump would start it but there is no chances for complete set. I've been given second hand pump that is it. Yes I have vin and pin from new pump.Any more suggestions?
HI IF YOU HAVE PIN CODE FROM NEW PUMP YOU SHOULD RESET IT AND THEN PROGRAM IT WITH OPCOM USING OLD PIN CODE
Do you have pin of the car?
Go to engine menu and choose in Programming
[Reset engine ecu) Now you will use the pin if the new pump.
Then you will choose Programming  ecu again and you will use the pin of the car.and make all the functions that will be asking too..
Wait a minute friend.
Your car is ASTRA G and the donor car is from Vectra C?
I think that you will have problem!!
Any progress?
Opel
05-31-2026, 02:15 AM
05-27-2026, 08:25 PM
05-19-2026, 12:14 PM
