  • 76 Vote(s) - 2.79 Average
zafira pump psg16 replacement and programming
37
hello guys
Much appreciated for all of your help The end of the story is fixed ofcourse .I hyad an issue with communicatioon tech2 to globaltis - the reason was diferent software version . updated tech2 and they started talking . Right. Connected tech2 to the car - sps - pulled ID -went to globaltis - downloaded calibration file for the vin -connected tech2 to the car and started flashing . It erased ori file and stopped on 13 % saying programming failed. So the ecu flash blank . No good . Then took advice from one of my friends and we went online . By connecting to gme website ( having access and login) connected the car through tech2 to the Opel website. Then Flashed psg16 from the serwer and we are done . Small issue with acc pedal sensor sorted next day and car wqent to the customer . Many thanks guys for all comments . It did worked out.
Thanks given by: jeff
38
(08-04-2012, 11:24 PM)sokisoki3 Wrote: Thanks Ash
As mentioned above it is psg16 two plug connector . i will try this procedure suggested by jeff and you . I will let you know.
hi above post is correct for your twin plug pump psg16 module,i have programmed these so if unsure i can also helpWink
hello friends, I zafira control unit with pump psg16.
my car will not start the engine and release the error code P1630 and p0606. What should I do when I have these errors? thanks
Check +12 and ground in wiring if ok, replace Psg16 unit.
(03-26-2013, 10:43 PM)daniel978 Wrote: hello friends, I zafira control unit with pump psg16.
fix sensor cable,in ouside area is broken,mast be 4 wires.
Large nations behave like gangsters ,and young as prostitutes  If i was able to help  write in post and add rep !
[Image: bulgaria.gif]if some one whant some file from my posts ,please  on PM
better explain thanks
(03-26-2013, 11:16 PM)Tanitos Wrote: Check +12 and ground in wiring if ok, replace Psg16 unit.
remuve pump from car,if you are not mechanic see autodata for details ,there is procedure how to remuve ppump,then remuve cover of pump ,ATENCIONE!!! sensor cable ig goin out form protected cover and is protected by small metal plate ,fixet with two bolts,remuve carefully!!!you need to disansemble ECU form body then see sensot insideThe cable usualy broken in sensor side -pump body/ there will be oxidized surface there is your problem.
Cable is hard to repair!secon hand you will not find!
(03-27-2013, 02:31 PM)zoro1 Wrote: remuve pump from car,if you are not mechanic see autodata for details ,there is procedure how to remuve ppump,then remuve cover of pump ,ATENCIONE!!! sensor cable ig goin out form protected cover and is protected by small metal plate ,fixet with two bolts,remuve carefully!!!you need to disansemble ECU form body then see sensot insideThe cable usualy broken in sensor side -pump body/ there will be oxidized surface there is your problem.
no one has a photo or a picture for this?
and my first time on this problem
Opel
05-31-2026, 02:15 AM
05-27-2026, 08:25 PM
05-19-2026, 12:14 PM
