  • 76 Vote(s) - 2.79 Average
zafira pump psg16 replacement and programming
55
shami 1 you are saying no communication with ecu. This could be the problem first. Then you cans tart thinking about resetting progarmming etc.
hi, and excuse me for i entered in middle of topic with my questions
I have a vectra c that it need to replace psg16
Pump was changed before from others but car was not started
i have opcom carprog tech2 orv for use on this car
i tried to read pin of pump that must replace old pump and appears 0000 or blank space
i have tried to read it and with carprog but no any resul
single chance appears to be to know pin from vin
wolozgf6838094874
if have and any suggestions
many thanks
have a nice day
With what tool you try to read pin?Only carprog and tools like carprog can do this.With tech you can recive pin from PCMCI card.Pin form vin you can get form opel dealer.if there is blank space then pump may be vergin?
Large nations behave like gangsters ,and young as prostitutes  If i was able to help  write in post and add rep !
[Image: bulgaria.gif]if some one whant some file from my posts ,please  on PM
Guys just to infrom you that it possible to Clone , Repair and BDM read of PSG16 pump.
FULL. MPC+EE+Flash
You can use any opel donor pump and reflash with ori data from your pump. No SPS, NO Pin and No programming via OBD
Thanks given by: javiercj , darka7 , TizWaz
59
Can you please explain in details how you did that?
What tool do you use to read the pump, how did you connect it , and what software?
I have a problem with my own car. OP-COM gives:
OP-COM - KW2000 Communication Window> 2003|Frontera-B|Engine|Y 22 DTH
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L06BG763V503451
vehicleManufacturerECUHardwareNumber 24451347 KG
systemSupplierECUHardwareNumber: BOSCH010000001401
systemSupplierECUHardwareVersionNumber: 0000
systemSupplierECUSoftwareNumber: 6UBMS010_S
systemSupplierECUSoftwareVersionNumber: 044F
exhaustRegulationOrTypeApprovalNumber: B03004
systemNameOrEngineType: Y22DTH
RepairShopCodeOrTesterSerialNumber: Not programmed
ProgrammingDate: FFFFFFFF
Identifier: 1450
VehicleManufacturerSpecific: 0470504207
Total number of fault codes: 3
P0638 - Throttle Control Circuit Negative Deviation
(05) - Present
P0606 - Electronic Control Unit (ECU) - Malfunction
(0A) - Not present
P1634 - Injection Pump Malfunction
(0C) - Present
First one I understood is from broken trottle body - p0638
Second one is appearing and going, and the third one - also.
Last one is the problem, as I understood.
The car is choking, black smoke coming out, and engine stops. It sometimes reaacts to gas pedal, sometimes not. When it reacts, it is for some minutes and you can even drive it, but for some meters.
I have a chance to get a pump from the same car and from Signum. After reading everything here, I did not understood how to get my current pin?
I have galetto1260, ELM327, op-com. Can borrow carprog also.
Dexter you written all over the internet that your solution is reading
"FULL. MPC+EE+Flash"
but this is not trough It is not read main flasch at all, checked xprog m, galetto, and bdm
May be it is good to clone the immo data and that is all.
61
(04-14-2014, 12:45 AM)auto-krak Wrote: Dexter you written all over the internet that your solution is reading
hello
please
many times when reset pump psg16 with carprog in Bank.
It cannot be reset. or does not allow me to remove the pin.
There is some soft or program or connections that allow me to read and reset pump bench
Thank you
hello friend
one consult
please help
the car is opel zafira 2.2 dtr
i have pump psg16 it read eeprom with carprog but not appear pin-code . it reset with carpROG and changed vin-kilometers but to connected the interface op-com in the car. the pump is not reset and cant do it adapter immobilizier in the car.
i have got read the eeprom before i reset the pump.
can you please help me to get pin-code with the eeprom file reading or the pump vin-number?
vin-number pump donor is: w0l0ZCF6921061059
thanks
try 6688
GM OPEL/SAAB  EDC15-EDC16-PSG16-EDC17-ACDELCO-DENSO- remapping , tuning , programming bow
Opel
05-31-2026, 02:15 AM
05-27-2026, 08:25 PM
05-19-2026, 12:14 PM
