You need to use Tech 2 and GlobalTis, to reflash the pump with the correct software, this will overcome the problem you will encounter if you fit the Vectra C pump to your Astra G and try and program it to your car with the security code, it wont work until its been reflashed with Tech 2.
[email protected]
zafira pump psg16 replacement and programming
75
12-20-2017, 07:30 PM
try 0494
GM OPEL/SAAB EDC15-EDC16-PSG16-EDC17-ACDELCO-DENSO- remapping , tuning , programming
76
04-18-2018, 01:06 AM
(08-19-2017, 07:34 PM)andyl Wrote: You need to use Tech 2 and GlobalTis, to reflash the pump with the correct software, this will overcome the problem you will encounter if you fit the Vectra C pump to your Astra G and try and program it to your car with the security code, it wont work until its been reflashed with Tech 2.
Can you do it with MDI- GM?
79
04-22-2024, 07:16 PM
hy. help please with pin from dump psg 16 with car prog. on car prog at pin is ffff at both pump.
80
04-22-2024, 08:34 PM
Opel original=PIN code 9070
Do not forget to press Thanks and Reputation buttons...
Thanks given by: danieltnokia2000
