  • 202 Vote(s) - 3.17 Average
100
(03-16-2014, 11:00 PM)camaro Wrote: Hello,
New EPC key, is much shorter than the old
EPC Key and it I do not even work there
This key is used inside ewa net when you configure Server access parametrs by the way this keygen unlock Data Card. Use this key befor installation EPC
Thanks given by: camaro
101
Maybe I've misunderstood here, but I try and edit the new key
with the new and old generator but I only get activated with
the old generator with the long key one, the new EPC net keygen
that gives me a short key and this dont work.
Sorry abaut my bad english.
Okay, so you think I should delete everything and to install in new and entering
New EPC Net key before I automatically installed EPC again?
hello, I have a problem with ewa net, I wis updated in 01-2014, but crashes on startup java stop wis, it is a problem happened to others?
I have to reinstall everything, if you are starting from what basis?
my pc has xp creates problems?
may depend on the activation key, I have used the old generator
many thanks
just got a new hard drive for my t30 re newed all my keys for xentry das and epc when i want to open epc in ewa i get 'your current security settings do not allow this file to be downloaded' i know this is due to the IE security setting but how do i access them there tab simply isnt there??
(05-09-2014, 12:36 AM)sam13 Wrote: just got a new hard drive for my t30 re newed all my keys for xentry das and epc when i want to open epc in ewa i get 'your current security settings do not allow this file to be downloaded' i know this is due to the IE security setting but how do i access them there tab simply isnt there??
fixed -
run gpedit
[Computer Configuration or User Configuration]\Administrative Templates\Internet Explorer\Internet Control Panel
sort out internet options tool bar and enable downloads
SOLVED049
Thanks given by: mercibil
105
dear all.. i have a new problem with epc :-} ..... every time i reboot the system , epc says
the key is invalid.. so i have to give it a new key... Wis as well.. i have tried deep freeze , date change, run as date software and all other ways i can do.. but problem exists... epc and Wis are 09/13 ...
can anybody help for this issue...
Thanks And Regards.
Handshake
R.N.A. Mercedes And BMW Learner.
Just noticed with the EPC 01.2014 I'm unable to get datacard for w221.
W211 - 210 - 203 - 204 all works but not for w221
(05-13-2014, 01:38 AM)karakan08 Wrote: Just noticed with the EPC 01.2014 I'm unable to get datacard for w221.
What is the build date of this W221?
I've no idea, just recieved the vin of a customer to check something and suddenly noticed the datacard button was greyed-out...
double checked it with my own vin numbers, there it worked
Users browsing this thread: 3 Guest(s)
