12,945
Thanks Given: 12718
Thanks Received: 36025 (3583 Posts)
3,563
136
Clean your Key wis ( open file Lic_Key.dat with wordpad location at c:\Documents and settings\all users\application data\licdir )
and insert again your key..
*1rrt0zsz25dbrjqsqi0vhhtz3jgkmyobyquzqyd0vszmw
regards
nemomd
Location OfflineJunior Member
27
Thanks Given: 126
Thanks Received: 168 (34 Posts)
105
10
I made an update to 11/2014 in the EPC-NET. Now the program will not start.
javax.servlet.ServletException: Servlet execution threw an exception
com.hp.tis.ewo.shared.filters.WebSphere6ScrapProductFilter.doFilter(WebSphere6ScrapProductFilter.java:125)
com.hp.tis.ewo.shared.filters.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:83)
root cause
java.lang.UnsatisfiedLinkError: Invalid DLL Checksum. Expected "b7d267e5d4b4d3da80a3308bef4c0eb2" found "605d93eff6f94cafef88d183cd0c32ae" in C:\Programme\EWA net\server\lib\CommonLic.dll
com.hp.tis.ewo.accessgateway.license.LicenseManager.initDLL(LicenseManager.java:1878)
com.hp.tis.ewo.accessgateway.license.LicenseManager.<init>(LicenseManager.java:611)
com.hp.tis.ewo.accessgateway.license.LicenseManager.getInstance(LicenseManager.java:671)
com.hp.tis.ewo.accessgateway.license.LicenseManagerFactory.getLicenseManagerInstance(LicenseManagerFactory.java:29)
com.hp.tis.ewo.admin.user.UserManager.hasUserCaseOnlinePermissions(UserManager.java:2772)
com.hp.tis.ewo.admin.user.UserManager.getAllItemsFromDBObject(UserManager.java:1621)
com.hp.tis.ewo.admin.user.UserManager.fetchItemEntryInternal(UserManager.java:1263)
com.hp.tis.ewo.admin.user.UserManager.fetchItemEntry(UserManager.java:1182)
com.hp.tis.ewo.accessgateway.proxy.services.usermanagement.HPLogonAction.execute_internal(HPLogonAction.java:705)
com.hp.tis.ewo.accessgateway.proxy.services.usermanagement.HPLogonAction.execute(HPLogonAction.java:603)
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:480)
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1420)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:520)
javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
note The full stack trace of the root cause is available in the Apache Tomcat/7.0.42 logs.
12,945
Thanks Given: 12718
3,563
136
Run as program with administrator sir.
junach
Thanks Given: 63
Thanks Received: 9 (5 Posts)
23
0
221
01-03-2015, 04:59 PM
(This post was last modified: 01-03-2015, 05:41 PM by junach.)
Hi together,
I installed wis standalone 10/2014 in a clean VMWARE system with Xentry 12/2014. Installation of Xentry and WIS works well, but when I open Wis I get the following error Massage:
Vehicle Identification number not found
Model/model designation not correct
Error is independent if I open Wis directly or via Xentry
Please help, I didn`t found a solution in the forum until now!
Thanks in advance!
[b]Solved by changing the license key!!!![/b]
nemomd
27
Thanks Given: 126
105
10
You can't get the datacard from WIS NET Standalone.
You need WIS NET under EWA NET for that.
151
Thanks Given: 1075
Thanks Received: 395 (156 Posts)
1,028
131
when realese wis/epc 2015 version?
