  • 202 Vote(s) - 3.17 Average
325
Please urgent help. I need to know what is the part number of the fan that is installed on the following fan drive: a0002003923. I searched for it on EPC but I didn't find it. Please help
Hello
can I please get a license for WIS ewanet type?
BC5FF4ACC618
Thank you!
(08-01-2015, 07:18 AM)Jonathan Wrote: Hello
BC5FF4ACC618
Thank you!
WISnet: UYRP4KMKBE49GRRCKZXB64YU92FTYWLWQB8CZB23G4DTJ2X6
Thanks given by: vincano , Jonathan , Yudi
328
Could I also get another one? for WIS having issues on one PC with it.
Thank you sir
BC5FF4BF3D53
(08-01-2015, 11:48 PM)Jonathan Wrote: Could I also get another one? for WIS having issues on one PC with it.
Thank you sir
BC5FF4BF3D53
WISnet: D9GMYS7NB655GYYCQRBHP35DTMY5L2A3X2TX3S98YTTANCCQ
Thanks given by: Jonathan , daxxer
330
Hello. I`m trying to install Wis Standalone 04.2015 and I have one problem. Wis key in starkeycenter is ok, I mounted Wis DVD 1of2 to virtual drive press sdswicth.exe installation is started and after Wis Icon is added to the desktop come error "No valid Wis medium found on the system" I tried download Wis again 2 times and still the same. D2ksetup trick applied. Where is problem? Thanks for reply.
Hi to all,
I posted my problem in tread:Mercedes EPC/WIS/EWAnet Video Installation Guide 2014 From Yudi nearly a month ago, but no help so far. I hope better luck here.
Stack at first step installing Java. Error 1723. There is a
problem with this Windows Installer package. A DLL required for this
install to complete could not be run.
I tried to uninstalled my java manually and than install java from DVD, the same error.
If I leave java 8.51 on my PC and skip installing java from DVD and start installing EWA, EWA wizard starts, I select English, click OK, select directory, click next, Installation Manager starts, nothing happens for long time.
I click Next, popup reads: Setup "red X "The system files could
not be installed. Click OK, popup goes and also Installation Manager.
Maybe this will help: I have a desktop PC ,Intel i7 2.7GHz processor,6 GB memory, SSD 260 GB HDD, Win7 64bit Ultimate,
IE11, Java 8.51. Running already Citroen and Peugeot car software.
Thanks for patience and help, regards tony.t.
Have you tried JAVA 7??
Thanks given by: Yudi , avandgarde , tony.t
333
(08-16-2015, 08:27 PM)Rocinante Wrote: Have you tried JAVA 7??
I tried java6 and java7 from EVA iso file after I deleted my java8 and cleaned reg. No luck, the same error.
I am sure now that Citroen SW on my PC preventing installation of EWA net (it stopped working).
Starting with new install, will report when finish.
06-12-2026, 07:11 AM
05-25-2026, 03:59 PM
05-17-2026, 04:17 AM
