  • 202 Vote(s) - 3.17 Average
433
(01-31-2016, 11:34 AM)zdzich Wrote: I have the newest WIS that I recently got from this forum but it doesn't include the database for smart cars. How can I add the smart cars database and where do I find it ?
Are you sure you have the correct licence?
Thanks given by: ToMiBoY , Rocinante , jahacmm
434
Hi m8's!
I have installed EPC 06/2015 and i have two problems.
First is that i have to start manually ewa admin tool so i can have access to localhost:9000 and second problem is that when i try to run EPC i get Java error about failed to validate certificate, the application will not be executed:
java.security.cert.CertificateException: Could not verify signing in resource: http://localhost:9000/EWA-net/download/jars/coreClient_Res.jar
at com.sun.deploy.security.TrustDecider.ensureAllJarEntriesSigned(Unknown Source)
at com.sun.deploy.security.TrustDecider.getValidationState(Unknown Source)
at com.sun.deploy.security.TrustDecider.validateChain(Unknown Source)
at com.sun.deploy.security.TrustDecider.isAllPermissionGrantedInt(Unknown Source)
at com.sun.deploy.security.TrustDecider.isAllPermissionGranted(Unknown Source)
at com.sun.deploy.security.DeployURLClassLoader.getResourcePermission(Unknown Source)
at com.sun.deploy.security.DeployURLClassLoader.getResourceAsStream(Unknown Source)
at java.util.ResourceBundle$Control$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.util.ResourceBundle$Control.newBundle(Unknown Source)
at java.util.ResourceBundle.loadBundle(Unknown Source)
at java.util.ResourceBundle.findBundle(Unknown Source)
at java.util.ResourceBundle.getBundleImpl(Unknown Source)
at java.util.ResourceBundle.getBundle(Unknown Source)
at com.hp.tis.ewo.clienttools.trigger.AutoDeploymentTrigger.<init>(AutoDeploymentTrigger.java:95)
at com.hp.tis.ewo.clienttools.connectivity.http.EwaHttpUrlConnection.registerTrigger(EwaHttpUrlConnection.java:508)
at com.hp.tis.ewo.clienttools.connectivity.http.EwaHttpUrlConnection.getBaseHttpConnection(EwaHttpUrlConnection.java:629)
at com.hp.tis.ewo.clienttools.connectivity.http.EwaHttpUrlConnection.<init>(EwaHttpUrlConnection.java:438)
at com.hp.tis.ewo.clienttools.ServiceFactory.getConnection(ServiceFactory.java:216)
at com.snapon.sbs.epc.client.view.bl.ServerConnectionBL.sendToAppServer(ServerConnectionBL.java:176)
at com.snapon.sbs.epc.client.view.bl.ServerConnectionBL.sendRequest(ServerConnectionBL.java:104)
at com.snapon.sbs.epc.client.view.rh.LoginRequestor.execute(LoginRequestor.java:24)
at com.snapon.sbs.epc.client.view.impl.MBEPCApplication.main(MBEPCApplication.java:346)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.sun.javaws.Launcher.executeApplication(Unknown Source)
at com.sun.javaws.Launcher.executeMainClass(Unknown Source)
at com.sun.javaws.Launcher.doLaunchApp(Unknown Source)
at com.sun.javaws.Launcher.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.sun.deploy.net.JARSigningException: Could not verify signing in resource: http://localhost:9000/EWA-net/download/jars/coreClient_Res.jar
... 35 more
I tried several versions of Java but i have the same error.
Delete the current EPC & WIS shortcuts on the desktop. Uninstall the current Java & install the Java version in EWA.
After that: Go to control panel/Java/security. Make sure the security slider is on the lowest setting. Add http:// localhost:9000 to the exception list. Press ok/save etc...
Then Java/general/temporary internet files/view. A new box will open with EPC & WIS icons. Select EPC & press the green round icon with white arrow. Did EPC start? Do the same for WIS.
Afterwards select EPC & press the white small icon with black arrow. This will create shortcut for EPC. Do the same for WIS.
Art Tup
Thanks given by: gkatsogr , jahacmm , anvas69 , autoville , drcko , aminadav , autoseek
436
I think so. I tried both, WIS Standalone and WIS Standalone for Smart.
Post your ID
use this
http://mhhauto.com/Thread-New-Keygen-DAS...uto-member
Thanks given by: Rocinante , art_arev , ToMiBoY , jahacmm
439
hi
i have problam with wis 4.2014
please help me
windows 7
explore 8
(02-01-2016, 04:00 PM)iveco Wrote: hi
please help me
windows 7
explore 8
uninstall your java program at control panel then downgrade your java version installation
clean temporary files at java setting and made security lowest..
run again your ewanet page and wis/epc icon
regards,
Thanks given by: Floryn_P , jahacmm , ToMiBoY , art_arev , iveco
441
please help me
windows 7
explore 8
All you had to do is read this before posting
http://mhhauto.com/Thread-Mercedes-EPC-W...#pid619152
Art Tup
06-12-2026, 07:11 AM
05-25-2026, 03:59 PM
05-17-2026, 04:17 AM
