  • 202 Vote(s) - 3.17 Average
361
(09-26-2015, 12:31 AM)Yudi Wrote:
(09-26-2015, 12:07 AM)Mackhack Wrote: New images, new fresh install and it went through. Not sure what the deal is here.
Hello sir,
the problem is at your archive installation,
i think you downloaded the dvd epc with file type is folder, right?
please make file folder with iso file, then install with file iso
regards,
Correct. It was just folders. I did say that I created ISO files but it still didn't work.
Hello guys,
I try different methods to make active Datacard in epc and wis but I did not succeed.
There is someone so kind to help me with the startkeys for epc\wis that activate also Datacard (I want Datacard for WIS more than for EPC, but for both is better)?
In this moment my ewa is functional except Datacard so other keys without Datacard are useless for me.
My lan id is: 002314A8B62D
thank you in advance
(10-15-2015, 09:38 PM)Zamolxes Wrote: Hello guys,
Your EPC Key..
t53rxzeyrjrlzwxeu7hmgqu6p3kv95s
regards
Thanks given by: ToMiBoY , jahacmm , vincano , Zamolxes , R.N.A , Floryn_P
364
Your EPC Key..
regards
Yudi you make my day more beautiful.
I want to ask you if there is any options to make wis to read data card info from epc or the details regarding the vehicle identification number or is necessary a similar key like the one for epc.
I already thank you so keep to rock our passion for cars.049
Regards
Hey,
i found my old IBM T61 and i need a new device
would Xentry work on it without problems?
If I helped you, please press this [Image: postbit_reputation.gif] and that [Image: postbit_thx.gif]on my post
(10-19-2015, 01:37 AM)erazer Wrote: Hey,
Im using a T60 without any problems. I suggest a SSD though to compensate for the slightly slower CPU compared to more modern laptops.
Dear All,
I have a problem and need your help. After installed EPC 2015-06 and re-boot, there has a message pop-up said "Cannot start service from the command line or a debugger. A windows service must frist be be installed (using installutil.exe) and then started with the ServerExplorer, Windows Services Administrative tool or the NET START command." Also, SD Connect toolkit is disappeared. What can I do? Is there any solution?
There is always more to the story than I just did xyz. By just installing or updating EPC, SD Toolkit won't disappear. My recommendation: format and start from scratch. If your system is that sketchy who knows what else is not properly working. And troubleshooting might take more time than reinstalling everything.
Dear Sirs,
How to create WIS/ASRA EPC shortcuts on desktop on Xentry x.2015?
Because I got this message: Error 462 EWA Session Token expired.
06-12-2026, 07:11 AM
05-25-2026, 03:59 PM
05-17-2026, 04:17 AM
