  • 202 Vote(s) - 3.17 Average
406
(01-13-2016, 11:09 PM)Mackhack Wrote: Reboot, kill NetworkFilter.exe in Taskmanager, launch EWA-Net then EPC.
I think at Windows 7 not have process "NetworkFilter.exe" Big Grin
Thanks given by: Floryn_P , jahacmm
407
I don't know I didn't read he had Win7.
(01-13-2016, 11:46 PM)Mackhack Wrote: I don't know I didn't read he had Win7.
If you see the picture.. you will found button Start windows logo.. that is W7 style
Thanks given by: jahacmm
409
Sorry guys I have the system Windows 7/32Bit. I have three days that I try in all ways to solve this problem of version 09.2015. Sweating Tomorrow will be another day of battle.1087
Run cleanEWAintstallation.vbs & start from 0. Start with WIS 10.2015 Full, then EPC 06.2015 Full & Update to 09.2015.
Art Tup
Thanks given by: Rocinante , ToMiBoY , jahacmm , Floryn_P , om612
411
Hello guys this morning I installed EPC on W10/64Bit from scratch and everything went ok. Let's see if I can make it work even on W7/32Bit on the main PC after many tests, now I try to do everything from scratch cleaning also logs. What interests me more to get it running on W7/32Bit.SweatingSweating
Thanks a lot.
Hello guys. No way I did just as he said "art_arev" part EWA Net Server but now part EWA core database1087. I returned again to version 09.2014 and works perfect, and wait a few newer version to try. Thank you all for help.
Hi guys i got a problem with my WIS-Installation:
I think the problem is following: I installed EWA and EPC. Both are working fine. After that i made the mistake to install the WIS database NOT via the "extended-tab" and "update wis-button" in the admin-tool, but via the "wis-tab" and "install wis-database".
From the point "test new wis database" during the installation, i get the error that the installation failed...
Now i deinstalled everything, even cleaned the registry and installed again. Everything worked fine but when i try to start the WIS-database in the EWA admin tool i get the message "Starting of the wis database has been failed"
Any ideas?
Thanks!
(01-21-2016, 02:37 PM)Mr.Ignacio Wrote: Everything worked fine but when i try to start the WIS-database in the EWA admin tool i get the message "Starting of the wis database has been failed"
That sounds a bit conflicting. What do you mean by "everything worked fine"? Even WIS worked fine?
What if you restart EWA Admin tool, how are the "traffic lights"?
Have you tried to start services from computer management?
06-12-2026, 07:11 AM
05-25-2026, 03:59 PM
05-17-2026, 04:17 AM
