  • 202 Vote(s) - 3.17 Average
343
    no, it was not found !!
hello there,
did someone have the same problem when searching for a model at EPC 09.2013 giving the message: INVALID MODEL/DESIGNATION; even with a specific ident. nr. of a vehicle it gives the same message!
By the way there is nothing in drop-down menu ??
Could it be the license key ? My lanid is the following one: F80F411E96EB
thank you in advance
(09-04-2015, 12:14 AM)gonix Wrote: And, the database status for EPC is marked: ERROR !
is there a solution for this ?
Sounds like you should fix your EPC database. Didn't you get any error messages when you installed the database for EPC?
Thanks given by: Yudi
346
i have updated to 09.2014 few hours ago; and now database status is green-OK; but the same problem when searching for a model= INVALID MODEL !!
(09-04-2015, 01:18 AM)gonix Wrote: no, it was not found !!
It wasen't there because you are not using EPC correctly--to use EPC correctly you must have the VIN or if not then you must know what assortment class and model to search---
In your case you are looking for 954 model designation---that is assortment class for trucks--so click on trucks(within the assortment class box) then within(trucks) the model designation you will find the 954 series.
You need to read more!!Beer
348
(09-04-2015, 10:18 PM)gonix Wrote: i have updated to 09.2014 few hours ago; and now database status is green-OK; but the same problem when searching for a model= INVALID MODEL !!
after a restart the database status turned at the earlier state; you can check the attachment !!
Hello. I need wis key. Mac address is 001641DD0BF6. Thank you! Smile
(09-13-2015, 10:29 PM)miniveho Wrote: Hello. I need wis key. Mac address is 001641DD0BF6. Thank you! Smile
WISnet: 3HXLS9EFR83M7TCF6EWTYU43UW9AW62ZZ3KCDUWWQ8R9LUH9
Thanks given by: ToMiBoY
351
Hi guys, I'm trying to install EPCnet 6.2015. I tried it on different computers but I always get the same problem. The installation stalls at 14/18 HPhookPost. It just won't finish this part. Never had it before with any other setups.
Anybody has an idea what to do?
Thanks.
06-12-2026, 07:11 AM
05-25-2026, 03:59 PM
05-17-2026, 04:17 AM
