please.. help!!!I installed mercedes epc 11/2014, installation ok, but when you start .. I get the error message " localhost no connection"......I installed on xp sp3. what to do ?? thanks
[email protected]
229
02-05-2015, 02:11 AM
(10-09-2014, 02:32 PM)Motasem Wrote:(10-09-2014, 06:06 AM)Geniusman Wrote:(05-24-2014, 01:12 AM)scorpion4x4 Wrote: Hi everybody, i have "succesfuly" instaled WIS/ASRA EWA-NET Full, everything appears to be ok, but when i click on the WIS button nothing happens, internet explorer opens a blank page, but not the application. EPC runs fine.
Any help is fully appreciated.
I beleive is something about the server
This is the address shoen in explorer:
http://localhost:9000/EWA-net/Login/startWIS.do;jsessionid=6C0690AD1FC6A5372F7E7B94CF1D54A8.server1
regards
same problem
What is the solution for this??
thanx in advance
Friend
it is easy
your star is blocking any insulation on your system AND THAT IS THE PROBLEM
SO
go to regedit > my computer > HKEY_LOCAL_MACHINE > SOFTWARE
FIND "STAR DIAGNOSE" AND CHANGE IT TO "STAR DIAGNOSIS"
REINSTALL IT AGAIN
THEN CNANGE BACK "STAR DIAGNOSIS" TO "STAR DIAGNOSE"
INFORM ME WITH THE RESULT
ENJOY
MOTASEM
After trying every solution possible i had to unistall everything, remove registry keys and delete db folder. Installed EWA EPC and Wis 01 2014, it´s working and i´m afraid to update.
regards
Thanks given by: ToMiBoY
230
02-07-2015, 12:08 PM
hello,
i have the EPC 10/2014 update DVD , but to install EPC i need the 09/14 full DVDs. (it says no valid medium found (i have only 09/13Full))
can someone help me out
thanks
thanks
231
02-07-2015, 02:28 PM
(02-07-2015, 12:08 PM)marcash Wrote: hello,
thanks
What sort of help are you after? DL links for the 09.2014 release you should be able to find from this forum, keep searching. You cannot solve your issue without the three DVDs from the baseline release.
ok now i found it , i search only in help section and not i the download.
sorry for that
sorry for that
233
02-09-2015, 10:09 PM
(This post was last modified: 02-09-2015, 10:12 PM by MB-DiagMan.)
hello everybody.
I have some problems with my WIS and EPC 11/14.
If i try to start it with its desktop button, I get the popup-window below.
Does anyone know how to fix this problem?
Thanks in advance for helpful answers!
HELPFUL? >> Press "Thanks" and "Reputation"
234
02-10-2015, 05:46 AM
(02-09-2015, 10:09 PM)MB-DiagMan Wrote: hello everybody.
try to uninstall your java 7.xx version. and then install java 6.30 instead..
Thanks given by: ToMiBoY , DBmhh , MB-DiagMan
![[Image: signaturemhhauto.gif]](http://software-otomotif.com/source/signaturemhhauto.gif)
