Dear MHHAUTO M8s
From all your posts I did notice that most of you are newbies in the installation of MB software and you are using install instructions without reading error messages or incomplete windows format with all correct versions needed files like java, adobe, net framework, ....... also the correct drivers
"AND THAT IS NOT SHAME OR A DEFECT IN YOU BECAUSE YOU NEED TO SOLVE THE PROBLEM AND THAT IS HEALTHY"
such knowledge is important
For the members and m8s who install WIS AND EPC after 2008 when XENTRY is released they know that XENTRY is a console program to run DAS and HHT software from inside, So XENTRY is a console software coz it runs on production of MB, SETRA, MITSUBISHI, ..... & others, as well as EWA it is a console software runs WIS, EPC,... form inside
that is why most of us locking for DAS standalone file to run it , and that is a fact
DAS standalone will never do SCN coding unless you run it thru XENTRY and that is a fact of MR MB modifications
let me explain
1- your are installing EWA, and EWA is a console program contains functions to run WIS, EPC, and other software from inside
SO when you install EWA you should not install WIS
if you do so it will not work and you will start
it is conflicting with what you have done
you must know the following
1 - 1 you did install the console software of EWA , not EPC OR WIS
1 - 2 after installing the console program you need ONLY to add data of EPC & WIS to the console program of EWA
using the admn tool
FOR that you must know you install console and modifying it by reinstalling WIS and that is wrong
2 - Installing WIS OR EPC as STANDALONE and EWA are different things and never connected to each other
so be smart
3 - Some cases you should read about some software requirements such as JAVA in this case YOU SHOULD USE THE CORRECT VERSION and it is in the install DVD and you should be offline when you do that , in some cases you are not able to install it coz you are not allowed in some places if the world or for some reason JAVA state it
So installing old version of EWA 2012 (JAVA 6) on WIS 2014 will not work unless you update JAVA to 2014 requirement level witch is JAVA 7
4 - In some cases you should know that DAS and XENTRY installation prevent some programs to be successfully installed so you should do the registry trick witch is shown in earlier post
just read carefully what I did in this post
http://mhhauto.com/Thread-Mercedes-EPC-W...#pid327827
HOPE THE BENEFIT TO ALL
MOTASEM
