[email protected]
119
05-19-2014, 10:52 PM
Remember there was a big change in version 03_2014 Tells us how you updated??
120
05-22-2014, 12:37 PM
Does EPC & WIS work on Windows 7 64-bit? I get a error that i'll need 32-bit java.
121
05-23-2014, 01:18 AM
Install 32bit java then.. you can run 32bit java on a 64bit system..
just not the other way around...
122
05-23-2014, 01:39 AM
got the datacard working in 09.2013 but when I do export datacard I don't see the SA-Codes with the options.
Only seeing SA-Codes without options.
any fix?
any fix?
123
05-23-2014, 08:47 AM
(05-19-2014, 05:42 PM)alptegin Wrote:(05-19-2014, 03:37 PM)alptegin Wrote: Hella MHH;
today i updated to 4.2014 epc. Latest 01.2014 fine works. But Now not run the java. it's uninstall and clean install. is there also solutions ?
answer please
Uninstall all installed Java, run EWA net and select in left menu Downloads, install Java from here. New version 04.2014 use Java 7.0
Thanks given by: ToMiBoY
125
05-24-2014, 01:12 AM
(This post was last modified: 05-24-2014, 03:14 AM by scorpion4x4.)
Hi everybody, i have "succesfuly" instaled WIS/ASRA EWA-NET Full, everything appears to be ok, but when i click on the WIS button nothing happens, internet explorer opens a blank page, but not the application. EPC runs fine.
Any help is fully appreciated.
I beleive is something about the server
This is the address shoen in explorer:
http://localhost:9000/EWA-net/Login/startWIS.do;jsessionid=6C0690AD1FC6A5372F7E7B94CF1D54A8.server1
regards
regards
126
05-24-2014, 09:06 AM
I solved the java problem, but can't install EPC. I got the 2013/09 files, but it doesn't recognize.
Picture of the error: http://i.imgur.com/vXdCRkN.png
