69
Thanks Given: 2403
Thanks Received: 1535 (582 Posts)
1,027
44
Remember that with WIS standalone you need to have a DAS Xentry version installed and your desktop must be setup correctly and as you say you must have the standalone keys installed----very different from the EWA NET installation.
Bari87
Location OfflineJunior Member
0
Thanks Given: 25
Thanks Received: 4 (2 Posts)
0
Hello together,
i have a little problem too..
Have downloaded the Xentry/DAS/EPC/Image 7.2014 for a Dell and switched successfull to a "good Hardware" - Fujitsu D9510 with enabled AHCI and SSD (makes fun!) - insert drivers, delete the old one etc. everything no problem since i am deploying the Windows-Images for our company.
But the WIS never worked and in the Serverlog i always get java framework errors. If i remove java runtime and install it again, the WIS will work so long as i doesnt reboot the system - so its not a good solution. So i have remove the complete Ewa/WIS standalone, and wanted to install it again, for example the 9.2014 Version, but i always get a error on step 3/18 "jre install" - "Internal error" "Runtime error 429" "ActiveX cant create object".
Have you see it this again?! Anyone an idea?!
The system is clean, Error log is fine, everything looks fine from the Windows aspect.
Thank you for your help and best regards from Munich
Bari
